loosing coolant
Old Jun 3, 2006 | 02:10 PM
eadwiggi's Avatar
Default loosing coolant
My 01 raptor 686 is loosing coolant and i don't know why. I just put a new water pump and coolant so i thought it might just be bleeding the system, but i've filled the resivior 3 times now. There doesn't appear to be any coolant in the oil or anywhere on the outside of the motor. My biggest concern is that it keeps heating up (or at least the oil light keeps coming on). Does a raptor have a thermostat? if not why would the coolant not be circulating. any ideas? thanks.
Old Jun 3, 2006 | 03:32 PM
Doctorturbo's Avatar
GOT BOOST!
"Loosing coolant; heating up."
Sorry dude, this is classic of a head gasket or crack problem. It's a closed system, so if you don't see any coolant on the ground or in the oil; that only leaves one thing left..............your burning it out the pipe.
You can do a pressure test to make sure.
I think the head is going to be coming off and a gasket changed out.
Old Jun 3, 2006 | 04:57 PM
eadwiggi's Avatar
how do you pressure test it?
thanks
Old Jun 3, 2006 | 05:13 PM
GOT BOOST!
Any radiator shop has a hand pump. They will take your radiator cap off and replace it with a fitting that attaches to the pump. They will pump up the pressure and take the reading and see if that pressure holds. If that pressure does not hold, you have a leak. If you don't see the leak on the outside of the engine, you have a leak on the inside of the engine. (head gasket or crack)
Warning: I have seen this test give false negitives, because of the defect being so small. The engine should be up to temp before doing this test.
Like I said above, all in all I think your going to be yanking the head off. If the thing does not leak on the outside, there is only one other possibility.
Old Jun 4, 2006 | 01:26 AM
Turtler's Avatar
You most likely have a bad head gasket. Happened to my 02 Raptor.
Old Jun 4, 2006 | 01:52 AM
mclach's Avatar
Sounds like a head gasket to me. burning it out the exhaust. Does the exhaust smell funny.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
