SP 400 Left front hub
Old Jun 3, 2006 | 04:38 PM
BART323's Avatar
Default SP 400 Left front hub
I have a 2001 SP 400 with about 580 miles on it. The left front hub has given me problems for the last few years. Now when I use AWD the left front hub won't disengage unless I flip the AWD switch off. The the hub releases and I am good to go. I can drive a few feet flip the AWD switch and it will work fine. But once the rear wheels slip and the fronts kick in the left will not release. The right side will release, I know this because the quad will pull to the left and be a real bear to steer. My question is what do I need to fix this problem. I have been looking for a new hub, but do I really need a new hub or is there a couple parts that need to be replaced. Any help is appreciated.
BART
Old Jun 3, 2006 | 09:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i heard that changing the fluid some times helf. havent had that problem as of yet ( knock on wood)
Old Jun 4, 2006 | 04:05 PM
BART323's Avatar
Thanks, I've tried the fluid and it still did the same thing. I wonder if the magnets are bad.
Bratman2
Aug 6, 2022 01:42 AM
TLC
Jul 25, 2015 02:24 AM
RticKwad
Jul 21, 2015 03:00 PM
tporath
Jul 11, 2015 12:31 PM
traumajunkie
Jul 5, 2015 03:03 PM
