torque specs
Old Jun 4, 2006 | 01:47 PM
bombrider04's Avatar
Default torque specs
I was wondering if anyone could tell me the torque specs on the ds engine or atleast lead me to a website with them thnx
Old Jun 4, 2006 | 02:01 PM
Scatterbrain's Avatar
For which part? I can look it up.
Old Jun 4, 2006 | 04:18 PM
I was just wondering where i could find the specs just incase i decide to take my engine apart so i can put it back together to the stock specs because I might want to upgrade to a larger bore sometime soon
Old Jun 4, 2006 | 05:13 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Bombardier DS 650 Torque Data
ENGINE
Engine Support M8 26 N•m (19 lbf•ft)
M10 64 N•m (47 lbf•ft) Note- Cylinder head bolts not to be torqued mare than 37 lbf/ft.
M14 135 N•m (100 lbf•ft)
Spark Plug 22 N•m (16 lbf•ft)
Magneto Nut 180 N•m (133 lbf•ft)
Starter 10 N•m (89 lbf•in)
Starter Red (+) Cable 4 N•m (35 lbf•in)
COOLING
Radiator Mount Screw / Nut 10 N•m (89 lbf•in)
Radiator Protector 2.5 N•m (22 lbf•in)
Temperature Sender 35 N•m (26 lbf•ft)
Water Pump Cover 10 N•m (89 lbf•in)
Fan Mount Screw / Nut 3 N•m (27 lbf•in)
Oil pressure Switch 15 N•m (133 lbf•in)
EXHAUST
Exhaust Nut 11 N•m (97 lbf•in)
Heat Shield Screws 10 N•m (89 lbf•in)
FUEL
Carburetor Mounting Clamp 0.6 N•m (5.4 lbf•in)
DRIVE TRAIN
Front Wheel Hub Nut 135 N•m (100 lbf•ft) (MINIMUM)
Rear Wheel Hub Nut 235 N•m (173 lbf•ft) (MINIMUM)
WHEEL
Wheel Nuts 52.5 N•m (39 lbf•ft)
STEERING / CONTROL
Upper / Lower A-Arm Lock Nut 60 N•m (48 lbf•ft)
Tie Rod Ends 75 N•m (55 lbf•ft)
Steering Arm (castellated nut) 75 N•m (55 lbf•ft)
Steering Column Support Screws 24 N•m (17 lbf•ft)
Handlebar Screws 24 N•m (17 lbf•ft)
Flanged Bearing Bolts 10 N•m (89 lbf•in)
SUSPENSION
Shock Absorber Bolt Front 48 N•m (35 lbf•ft)
Rear 85 N•m (63 lbf•ft)
Front Upper Swing Arm 67 N•m (49 lbf•ft)
Front Lower Swing Arm 67 N•m (49 lbf•ft)
Rear Swing Arm LH First Nut 100 N•m (74 lbf•ft), Unscrew Nut a Quarter Turn
Rear Swing Arm LH Nut 100 N•m (74 lbf•ft)
BRAKE
Caliper Brake Screws 24 N•m (17 lbf•ft)
Brake Disk Screws 34 N•m (25 lbf•ft)
BODY / FRAME
Front Bumper 24 N•m (17 lbf•ft)
Rear Extension Frame 48 N•m (35 lbf•ft)
Footrest 10 N•m (89 lbf•in)
Skid Plate 4 N•m (35 lbf•in)
Old Jun 5, 2006 | 04:21 PM
thanks omr I really appreciate it and u 2 scatter
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
raman8tor
Sep 20, 2015 07:35 AM
