Help.4WD not working
Old Jun 4, 2006 | 10:48 PM
fredbear92's Avatar
Default Help.4WD not working
Ive got a 99 xplorer 400.The front wheels arent working when 4wd button turned on.I have 4wd in reverse if the override button is held.I do have a working speedo.The hubs have fluid in them.And Ive got a new speedo sensor wire.The awd button on the right handlebar doesnt light up and my neutral indicator light on the pod doesnt work.I think all the wires under the headlight pod are connected.Any ideas??
Old Jun 4, 2006 | 11:05 PM
trailblazermudrunner's Avatar
i dont know if polaris have actuators on there awd system like a kawi does but if there is an actuator it may be gone im not really sure i got a kawi and a trailblazer i dont know much about the awd on the polaris's
Old Jun 5, 2006 | 10:18 PM
scrammersam's Avatar
i bet your wiring got messed up when you did the speedo work. was it workin prior to that
Old Jun 5, 2006 | 11:29 PM
Freedom500's Avatar
I would check the two switches on the trans, they control power to the 4X4 system. If the neutral light does not work and the bulb is good, also trans switches.
Old Jun 6, 2006 | 01:12 AM
i agree on the switches as Freedom500 said. i remember on mine the neutral and reverse light dont work and if i throw the shifter around they work for a bit, but it doesnt effect my 4x4
Old Jun 6, 2006 | 08:52 AM
fredbear92's Avatar
I put new speedo sensor over two months ago.It worked just fine until last weekend.Went riding over the memorial day weekend.All day friday it did just fine.Saturday morning and early afternoon it worked sporadically.By saturday evening and all day sunday nothing worked.Not sure when the neutral indicator light quit working tho.I thought there was a problem with mud buildup between the rotor and the speedo sensor magnet.Saturday night I took off the wheel and cleaned real good.Still didnt help.Im stumped.Thanks for responding tho.Scott.
Old Jun 6, 2006 | 11:19 PM
400L4x4's Avatar
I just got done doing this to my 94 400 4x4.The shift linkage gets just out of position and then the 4x4 doesnt work.Jack the atv up,disconnect the linkage,and move the shifter till
the wheels spin.Move the linkage back and forward until it is in the right spot and then it will
engage properly.But like said above a sensor could be bad too........
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
