Do ATV deraillers exist?
Old Jun 6, 2006 | 12:09 AM
jed250's Avatar
Default Do ATV deraillers exist?
I want to put a 14 tooth front sprocket on my 400ex to get more "pep" throughout my gearing. I realize I'll lose my quick 5th gear top end if I do this though. What I would like to do, is to somehow make a derailler system on my front sprockets. I'd like to have both the 14 and the 15 on the bike so that I can shift through them just like a bicycle. It would be like turning the 400ex into a 10 speed rather than a 5 speed.
Old Jun 6, 2006 | 01:56 PM
Spiketrx400ex's Avatar
I am sorry I don't have an answer for you but if you pull it off and get the bike work fine with two front sprokets please let us know how you did it
Old Jun 6, 2006 | 02:04 PM
jed250's Avatar
I think it would be a pretty cool thing to do. Although it would double the weight in the front, I doubt it will affect performance by a whole lot. You would probably be able to gain more performance than lost performance. I'm sure they don't exist as I've never heard anyone talk about it before. I'll see if Google has an answer...
Old Jun 6, 2006 | 03:49 PM
ONEANDONLYDWT's Avatar
I think if it were done it may be easier if you could change the rear sprocket up or down. like a pin that you could take out and move the sprocket that re-insert the pin?
DWT
Old Jun 6, 2006 | 04:43 PM
Scooter86's Avatar
Knows Old ATV Questions!
The problem I see is that unlike a bicycle drive system, there is a lot of thickness and not a lot of give in an atv chain/sprocket setup. Components are going to wear out way to fast unless the sprockets in use are always perfectly lined up. I'm sure something could be engineered, but in the end, is it really going to be worth it? You might be better off designing a quick change sprocket system and incorporating a chain tensioner in the design instead.
Old Jun 6, 2006 | 11:33 PM
JimmyHoffa's Avatar
...and at last we are saved from this thread by the logical words of a mechanically literate person like that guy^ (couldn't help but look at it)
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
trx430ex
Where to Ride
Feb 14, 2001 11:32 PM
CHICKENman
Where to Ride
Jun 11, 2000 08:38 PM
