Could it be posible????????
frist off are the trailblazer frames the same weight as the scammys and if so would it be possible to take the scammy front end and motor and put it in the tbs frame or would it make a diffrence if the frame was lighter? say if i could get ym hands on a scammy with a bad reare end for cheep and had the 250 frame would ever thin in the rear of the tb fit to the scammy motor and ever thing eles....or has any one ever dun this
if you could find the differential and transmission from a 250 xplorer (which was discontinued in like... '01) and maybe the case (because i think the drive shaft goes through it...) you could do this swap. This unit was a 4x4 2-stroke and used the same motor as yours. For that matter i belive it was the same frame. They were nice little machines... LOTS MORE POWER than little recons and stuff.
