Yamaha Warrior Clutch question?
I bought a warrior not to long ago that a guy said just died... and he didntk now what happened and so i took the clutch apart and there was only one cushion spring and after looking in a book i see that there is supposed to bet two. OR is there more than one clutch setup on different warriors. also the book says there are different sizes metals so i sure u can figure out everything but just not sure about the cushing springs
go by what the book says. i dont recall yamaha changing the clutch at any time on this bike. the major changes to it were on the '89 or '90 model when they moved the engine back in the frame, took off the recoil starter as a backup and repositioned the headlights and changed wheels/tires and did something to the carb to prevent the gas from "boiling" in the float bowl causing it to stutter (previous models did this).
you should get a barnett clutch kit or something like that and replace the clutch side b/c it obvioulsy needs some work in the clutch dept and someone may have TRIED and screwed it up. and since you have it apart, you might as well replace it with some sturdier (and maybe cheaper) clutch components.
Originally posted by: Speedy2222
hey austin... maybe if you unblock me on msn i can help ya with this...
what year is it?
i beleive there are 2 or 3 rubber cushions on most
what year is it?
for one your not blocked on my list, i just dont get on much during the week utill later at nights
and two speedy warrior god im just not sure u know what a cushion spring is becuase there not made of rubber they are metal...
and its an 98
Haha I think speedy is confused.
Well, the answer is that the clutches are identincal from the first to last production year. They should have 2 cushion springs in them, just like you found in the manual. If one is missing you should replace both of them so that they are matched, this will keep the clutch from dragging as much.
toonces
Oct 16, 2019 12:11 PM
Jul 7, 2015 11:00 PM
