trouble with 03 kodiak ultramatic
Old Jun 9, 2006 | 03:16 PM
funinthemud's Avatar
Default trouble with 03 kodiak ultramatic
i have a 2003 kodiak 400 was running great till last weekend all of a sudden transmision seens to slip well not changing gears actually checked the drain plug and released all the fluid in there but still doesnt respond everything looks good in there any ideas
Old Jun 9, 2006 | 06:26 PM
mclach's Avatar
check your drive belt.
Old Jun 9, 2006 | 10:57 PM
hondabuster's Avatar
At the minimum, youll need to pull the side cover off, and inspect. Most likely the belt has dirt or moisture on it. Check the clutch rollers too, as long as youre in there, and clean and lube them if necesary.
Old Jun 11, 2006 | 09:43 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
Also check the front intake hose into your auto case. They are known to fall off and let water in there and ruin a good ride
Buck
Old Jun 23, 2006 | 06:14 PM
Kodiak4502005's Avatar
Let any water that may be in your belt housing. You are more than likly going to have to rebuild your clutch. I have had to do it twice on mine no big deal just pay attention to what your doing when you take it apart. I took mine apart one time and I don't even know how it moved, it was packed full of mud and sand.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
YankeeRebel
Oct 6, 2015 06:44 AM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
