sunl 90 mini starting problem.
Old Jun 10, 2006 | 10:37 AM
MIDDLEAGEDCRAZY's Avatar
Default sunl 90 mini starting problem.
My grandson,s Sunl 90 has A problem starting. The bat. check's out fine. Yet it won't even turn over unless you jump it. Could there be another problem or should I just replace the batt?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 10, 2006 | 11:55 AM
rodneygt's Avatar
It seems to me if it will turn over when you connect the charger to the battery but wont with it disconnected then either the battery is bad or not charged enough. The original battery on my daughter's sunl 70 worked for about a month or so. I replaced it with one from wal-mart - acid type battery. It's been holding up for months.
Do a search and you will find some batteries people have used on these.
Rodney
Old Jun 10, 2006 | 12:18 PM
Thank's Rodneygt, What size of battery did you get from walmart? I have looked at them but the one's they have on stock seem to big to fit in the battery compartment.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jun 10, 2006 | 02:32 PM
rodneygt's Avatar
It says "ES4LBS Everstart Max" on the side. Take the old one with you to compare. The one I have now is the same length and width but it is shorter than the original gel battery. You'll can take the new ones out of the box to compare. Box size can be misleading.
Like I mentioned above, if you use the search feature on this forum you should find some other numbers - they're not all numbered the same. I seem to recall seeing some other numbers on this site.
Rodney
Bigredjeep
Apr 10, 2020 02:55 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
