06 Foreman Manual Shift
Old Jun 10, 2006 | 08:10 PM
econdave's Avatar
Default 06 Foreman Manual Shift
I believe I read this before but has anyone else had problems going from 1st gear to 2nd? shifts real hard. All other gears are fine. If so, will it get easier as I break in, only have 18 miles on it...thanks...
Old Jun 11, 2006 | 06:50 PM
JeffinTD's Avatar
Mine was stiff when it was new, especially the 1st time through the gears after a cold start.
It seems much better now, which I would attribute to it breaking in. I did switch to synthetic on like the 3rd oil change, though. You might also want to make sure the clutch adjustment is correct.
Old Jun 12, 2006 | 07:58 PM
KNOWSALOT's Avatar
The Facility
This is common place on all the Honda 500 models. Even the ES version...you can sense a bit more juice being pulled from the shift motor for that 2nd shift. But almost always, this goes away by the time you go through the frist and second tanks of fuel.
Old Jun 13, 2006 | 11:33 PM
devocorky's Avatar
If you search this you will see that it is common...goes away after a few miles.
Old Jun 14, 2006 | 07:15 AM
econdave's Avatar
thanks guys. I only have about 25 miles on it. It seems like it is getting better already... Man I love this machine, it will be a good workhorse...
mark23
Oct 1, 2015 09:57 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
