kaz 250 carb problems
i have a 250 kazuma it acts like it is starving for furl when u get into the throttle i have checked the lines and it is getting fuel, i have adjusted the carb doesnt seem to make much differance where it is set at. im at my wits end even tried carb cleaner plzzzzzzzzzzzzz any help
Also I have read alot about the fuel shut off restricting the fuel flow. Try to bipass the shutoff valve if equipped. Also you can change the needle position up or down to richen or lean the mixture at 1/4 to full throttle. Did it just start or has it always done it. If it just started then go with what bill said. There is alot of crap in these tanks and all it takes is 1 small piece to clog it.
hadaveha,
I agree 100% with Seadawg. He is not being a smarta$$. There is more than plenty of information to be found with regard to your carb problem. You just have to run a search.
Your best bet is to follow what Billl2099 and 2manytoys had to say. These are your best starts, after you run a search in the forum.
I'm sure if you ask politely, Billl2099 will PM you with all the information needed to get the carb back up and running. He is the one who has had firsthand experience with these carbs and knows what he is talking about.
You know what man, nobody is trying to be a smarta$$, we are just trying to say, do a little research or your own. Many of the fixes have been written many times over, just many different ways.
Good Luck.
SB
Good Luck.
SB
