Cracked Side Cover
Old Jun 14, 2006 | 03:21 AM
Polaris500HO4x4's Avatar
Default Cracked Side Cover
Hey guys i cracked my side cover on my bike in half.... its almost a perfect crack to line up do you guys think JB weld would hold it together otherwise im lookin at 150 bucks down the drain
Old Jun 14, 2006 | 07:01 AM
Instigater's Avatar
Yeah, You could do this: Make a little "V" along the crack, Get some 5 minute plastic weld (from TSC) and mix it up as directed. Push the the weld into the crack and smooth it over nicely, when it drys ( in 5 minutes, actually about 3.5 minutes, this stuff is quick) you can "overspray" with spray paint and depending on the location, it will blend in nicely. I did this on my front bumper, 2 pieces were completely busted out, and I was amazed at how well it looked. The longevity should be ok. If it messes up you are only out about $5 trying this method, give it a shot.
Old Jun 14, 2006 | 11:23 AM
BigDog800EFI's Avatar
When you say side cover. You mean clutch or the side panels.
Old Jun 14, 2006 | 01:37 PM
it would be the clutch cover
Old Jun 15, 2006 | 02:42 AM
i reinstalled the cover the JB weld seems to hold strong... no light can be seen through the crack so hopefully everything will hold up
Old Jun 15, 2006 | 07:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that jb weld is good stuff for sure.
Old Jun 15, 2006 | 03:41 PM
DSLKSL's Avatar
It would not hurt to spead some sealer on the inside for water proofing.
Njrider1230
Jul 29, 2023 05:16 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Reactant
Jul 27, 2015 07:45 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
