95 sportsman 4x4 very very hard starting
Old Jun 14, 2006 | 01:22 PM
michelle9's Avatar
Default 95 sportsman 4x4 very very hard starting
Hi
I have a 95 sportsman 4x4 I rebuilt the carb then it ran fine for about a week it started when it was cold ran good etc..Then I was using it to tow a lawn sweeper arond the lawn the thing just died. We could not get it started for a couple days checked the oil it was full but topped it off anyways put in about a 1/2 cup it started right up.I don't know if that had anything to do with it but that is what happened.
Ever since then it is still very very hard to start when it is cold 70-90 degrees outside temp. It takes about 5-10 min cranking It always sounds like it wants to start, it keeps on hickuping but can never catch.Checked spark it does have spark. (don't know how good of spark but I seen it in daylight without no problem.I changed out the carb with another used one because the original was pitted on the inside was thinking maybe it had something to do with that but still the same thing.It never backfires or anything when it does not want to start it just sounds like it is trying but no luck.
When it does finally start it runs fine like nothing was ever wrong.Never sputters or anything when it does catch.
I thought maybe it was the choke but when it does catch and run if I put the choke on it will die so it seems like it is working right.
Is there any kind of sensors that could be going bad?
Still a carb problem?
Need some ideas...
Thanks
Michelle
Old Jun 14, 2006 | 02:45 PM
Kerbbirds's Avatar
Take the air filter off and spray gas into the carb from the intake, if it starts better,it's a carb problem if not , check the valve clearance, it could be your cam is wearing out or maybe it's getting low on compression.
Old Jun 14, 2006 | 03:24 PM
400L4x4's Avatar
Is it a 2 stroke?
Old Jun 14, 2006 | 05:18 PM
michelle9's Avatar
Will check that out tomorrow when it is cold again again.
The compression is about 130
Old Jun 14, 2006 | 05:19 PM
michelle9's Avatar
Originally posted by: 400L4x4
Is it a 2 stroke?
yes it is a 2 stroke
With about 950 miles
Old Jun 14, 2006 | 05:49 PM
400L4x4's Avatar
Well 130 psi is good.The 2 stroke has low miles compared to mine(4300) and it runs so I
say to try what kerbbirds says first and then figure something out.
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
chinkapin
Jul 14, 2016 06:58 AM
1000gade
May 27, 2015 12:37 PM
