Does K&N really work better then uni
Old Nov 25, 2000 | 04:55 PM
Dirtpig's Avatar
I hear about K&N air filter working so much better then anything else..........including uni.
What does everybody think?
Old Nov 25, 2000 | 06:02 PM
JRM's Avatar
JRM
I have the K&N on my XR600R and the Uni on my XR250R. Both filter well, but the K&N clogs real fast if you hit dust after a river crossing. The UNI flows very well but overall Id say that the K&N flows better and the UNI filters better
Old Nov 25, 2000 | 06:07 PM
94DGblaster's Avatar
i agree with what was said above.
My K&Ns have let dirt into the carb..never a problem with my Unis
the K&N is higher flowing
Old Nov 25, 2000 | 06:23 PM
Dirtpig's Avatar
Thanks Guys.......I don't want anything on my Atv that lets dirt in the carb
Old Nov 26, 2000 | 02:39 PM
86atc250r's Avatar
I now have a nicely modified engine due to a K&N sucking dirt. Many will argue, but I have the modified engine to prove it, and they will not convince me otherwise, as I never had dirt in my intake tract until I put a K&N on (I ride and race in extremely dusty conditions sometimes).
If you must use a K&N be sure to get an outerwears.
Now, on another note. I have tested a K&N vs a stock filter with the stock flame arrestor screen (metal cage inside of the stock filter). I have found that even though a K&N will ultimately flow more, a stock filter flows more than enough for even a modified 400EX engine. The main restriction is the airbox intake.
We did some timed drag races on two different bikes and tested both the K&N and Stock filters on both, the filter did not affect the outcomes on either bike (yes we made sure jetting was correct, as we were also testing modified airbox designs the same day).
My recommendation, save your money & don't worry about sucking dirt.
Old Nov 26, 2000 | 08:59 PM
Dirtpig's Avatar
Thanks 86.......I think I will stick with the foam filter and not have to worry about it!
Old Nov 28, 2000 | 03:39 AM
THEXOTIC1's Avatar
Get a uni or other foam filter. KN is not the best for dusty trails
Old Nov 28, 2000 | 06:49 PM
tprender's Avatar
Read the find print on the K&N box. Do not use in dusty conditions. The K&N will flow more air, but it will let the very fine dust go though. Any foam filter will stop the fine dust. I was given a sample of this NO TOIL cleaner and oil for foam filters. From the use that we have had so far it works great in the dust that we have hear in Mo. It is also very easy to clean. I think earier than the K&N.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
