EBS on a 98 Scrambler? Is it possible?
Old Jun 21, 2006 | 01:46 AM
bjrjr16's Avatar
Default EBS on a 98 Scrambler? Is it possible?
Hello, I rode my 98 scrambler for the first time the other day, I really loved it, Mostly all I do is trail ride, I absolutely enjoy the ebs on my 01 and 05 sportsmans, you just let off and slow down, its great. If i let off on the scrambler I coast for ever and im not used to that. There a ton of hills around that I have to go on everyday, With the 01 sportsman I am still on the original brake pads because of how little I use them. My question is can I put ebs on my scrambler? What do I need to replace if I can? Theres a clutch kit in my scrambler right now, so if I have to replace the primary could I put the kit thats in my original clutch in the new one? Same goes for the secondary, I already have an ebs belt for it. Thanks alot, Brian
Old Jun 21, 2006 | 03:41 PM
conig's Avatar
you can convert to ebs but you need an ebs primary and secondary clutch and as a result its fairly expensive.
Old Jun 21, 2006 | 03:44 PM
bjrjr16's Avatar
What do I need for the secondary clutch and can i use my clutch kit in the new primary? I found a ebs primary with a broken sheath, could I use my sheath and guts for it? Thanks, Brian
Old Aug 23, 2006 | 11:52 AM
700r's Avatar
i have sportsman clutches on my scram
Old Aug 23, 2006 | 01:54 PM
SPYDEY4's Avatar
I guess its what you are used to. I have a 2000 Scrammy and got an 800 Sportsman this year and am finding EBS hard to get used to.
Old Aug 23, 2006 | 06:21 PM
ftwflh's Avatar
Go with a TEAM roller secondary and if you get it set up right you wont need EBS.
If you have an aftermarket secondary spring such as a HPD violet run it at 2-2 and this will help some too.
Old Aug 23, 2006 | 06:53 PM
awdowden's Avatar
I'm not a mechanic, so I can't tell you why...but Polaris cleary states not to put EBS clutches on non dual-range machines (like Scrambler, Trail Boss, etc). Again, not sure why.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
