'03 600 polaris
Old Jun 26, 2006 | 05:02 PM
Lonelyduke's Avatar
Default '03 600 polaris
Well, its back in the shop again, after having it out for 1 week. It overheated and blew out the coolant after riding for about 5 minutes around the yard. Dealor replaced the sensor on the motor and the radiator. Then figured out that the thermostat was not working properly. After replacing the thermostat, the water pump started leaking around the propellor shaft, so had to replace that seal. In the meantime they were trying to figure out why it felt like is was trying to go into 4-wheel drive and found that they are going to have to go into the front transfer case and replace parts there on both sides since both sides can be moved in any direction like the bearings are worn out. They've not gone into it yet. Since the middle of Feb., I've had the bike for 1 week, having to replace the battery during that time. Motor rebuild the first time due to bearings. $1700 the first time, don't know what it will be this time but luckily I have an extended warranty. If I can ever get it out long enough, I'm selling it. It should be about new by then.
Update!! It's the front axles that are worn out and at $250 apiece. Polaris at this time is saying they won't cover it. only 170 hrs on machine with a lot of that just on dirt roads.
Old Jun 26, 2006 | 05:54 PM
spyder6's Avatar
the 600's were never really very good, thats why they discontinued them. it might be in your best intrest to sell it actually, maybe a 700EFI is more you
Old Jun 26, 2006 | 08:03 PM
2manytoys's Avatar
If the 600's were never that good than the 700's were not either. The 600 and 700 are identical except for the cc of the motor. Out 600 has run great and its an 03 but the front diff keeps imploding.
Old Jun 27, 2006 | 11:17 AM
Sportsman6004X4's Avatar
My 2004 600 is still running great. I have done alot of mud riding with and have the usually problems with bearings and a the radiator fan and now the radiator needs a small hole plug. but all that stuff is from putting it through mud hole after mud hole. The engine is solid, the CVT is solid and the handling is great.
Old Jun 27, 2006 | 05:15 PM
spyder6's Avatar
i wonder what kind of maintnance this guy is running with his qaud. ive read through his story 3 times and ive never heard of all this stuff happening at once.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
