Help.4wd not working
Old Jun 27, 2006 | 10:20 AM
fredbear92's Avatar
Default Help.4wd not working
Ive got a 99 xplorer 400.My 4wd will not work in low range.It works in high and reverse.The neutral indicator light doesnt work.Ive replaced the tranny switch with a new one.The neutral light bulb is working.Ive got movement of my speedo needle and a new speed sensor.I cant tell if my awd light on the throttle switch is lighting up.Ive checked continuity between trans switch and the neutral light.There doesnt appear to be a broken wire anywhere.Im at my wits end and the local polaris dealers cant seem to help at all.Thought Id throw it out on the web and see if anyones had this happen to them.Not sure where to go from here but I dont want to take it in for repair at polaris.Any help appreciated.Thanks.
Old Jun 27, 2006 | 05:10 PM
spyder6's Avatar
are you positive that its not working in Low? the polaris AWD system requires that the rear tires move 15% further than the front wheels before the sensor kicks in and your front drive line is engauged. possibly the slow movement you havent gone fast enough or through enough slop to see if your front end kicks in. have you tried lifting the quad up off all 4 wheels, putting it in 4x4 and Low and seeing if your front end starts turning? if that dosnt work, im not sure on what to tell you. its very odd that it works in high but not low
Old Jun 27, 2006 | 05:29 PM
fredbear92's Avatar
Hello spyder.Yes Ive tried 4x4 on the atv lift.High side works and low side wont.Even tried spinning out in gravel.Same result.Dont know whats going on.
Old Jun 27, 2006 | 05:52 PM
spyder6's Avatar
i donno if this will make any difference in Low, but have you tried pressing and holding the Reverse/Overide yellow button with 4wheel drive engauged? maybe there is a short somewhere and it requires that to be pressed to give you the ok for 4x4.
Old Jun 27, 2006 | 09:43 PM
TBJAY's Avatar
i dont know anything about the t-case (or if there even is one) on a 4 wheeler but i know my jeep and what you are describing is a bad shift fork in the t-case for low range. if you had a jeep at least hope this helps
Old Jun 27, 2006 | 11:57 PM
spyder6's Avatar
i do! i have the rock-trac T-Case though, a bit different
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
