open exhaust
If you were running a stock exhaust you will gain performance if you jet it properly but it will be loud as hell. I would recomend at the least buying a end cap that way you don't gain enemies around where you ride.
You could just cut your stocker up. Cut out the spark arrestor and just leave the exit tubes... if you want to get crazy cut a round hole that will still hold in the baffle. There are a bunch of threads about doing this... do a search, you'll find the info you need to do it.
