500 HO nocking ?
Old Jul 5, 2006 | 03:34 AM
po500ho's Avatar
Default 500 HO nocking ?
hey, any ones 500 have a rotating nock @ idle that goes away at higher RPMs..............or can you hear your starter shims rattle at high RPMs. any thoughts......cant afford what the dealer may have to say,,,,,,,,,,,,,(pull the motor and we will see) not on my dime.................
Old Jul 5, 2006 | 07:58 AM
ftwflh's Avatar
If it is coming from the pull start side it is normal.
Old Jul 5, 2006 | 11:10 AM
NBsportsman's Avatar
If the idle is set too low the decompressor valve will hammer sounding like a motor knock. Also check the intake snorkels where they run up as they will vibrate where they touch together sounding like a knock.....
Old Jul 6, 2006 | 12:02 AM
flyinscrammy's Avatar
May sound too simple but it may be your belt knocking on the housing.... Learned the hard way when i paid those crooked dealers $139 to replace a $40 part.....
Old Jul 19, 2006 | 09:34 PM
HELLHOUND's Avatar
My 04 does the same thing (from day one)took it to the dealer this is normal it's has to do with the straight cut gears they are noiser than bevel cut gears but stronger which is why a lot of other ATV'S are quiet
Old Jul 19, 2006 | 10:33 PM
2manytoys's Avatar
The knocking sound is the primary clutch. It is normal with all the Polaris cvt quads.
BigBearFX
Mar 16, 2004 11:11 AM
TheWayOut
Sep 12, 2002 02:16 AM
spooge
Dec 22, 2000 05:12 PM
bigmanm
May 22, 2000 09:10 AM
rangerchet
May 2, 2000 12:37 PM
