wolverine u joint
Old Mar 13, 2004 | 09:45 PM
BigBearFX's Avatar
Default u joint
my wolvy is making a nocking or binding sound/ feel. the front universal joints seem a little loose. if they are no good would they cause a nocking or binding sound/feel
Old Mar 14, 2004 | 01:57 AM
Eceriderjbomb's Avatar
Default wolverine u joint
Check them and wiggle.. if they are you might need new ones. i'm not really sure. I never had that problem!
Old Mar 14, 2004 | 03:19 AM
Wolverine350R's Avatar
Universals to the front diff or the CVs on the drive shafts? I'd say check and see if the bearings are loose first by jacking the front up and wiggling the wheels(I've gone through 3 sets, guess I need to quit riding on 2 wheels). If those are tight check your universals on the shaft between the engine and differential (mine went bad and I replaced with better greaseable ones). I hope its not your CVs, cause I believe those are $$$. Good luck.
Old Mar 14, 2004 | 08:54 AM
Broken1Paw's Avatar
cv joints run about 220 per side.
Old Mar 14, 2004 | 10:09 PM
BigBearFX's Avatar
its the universals to the fron diff. the ones on the shaft from the motor to the front diff. they do wiggle a bit.
Old Mar 15, 2004 | 01:20 AM
Thats good to hear. I had my universals replaced recently, they are fairly cheap. Make sure to get greasable ones put in.
Old Mar 15, 2004 | 09:02 AM
BigBearFX's Avatar
how much did the shop cost in labor?
Old Mar 15, 2004 | 05:27 PM
wolverine68's Avatar
Believe it or not it's not the price he charges you for labor you should fear, but instead it's the price of the Yamaha u-joints. At least 5 times the price of going to a bearing supply house.
Old Mar 16, 2004 | 11:11 AM
BigBearFX's Avatar
ive heard you can get them at napa for around $20
89Lt250r
Sep 7, 2015 07:53 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Peter_
Jul 18, 2015 07:06 AM
