Brake adjustment on 400ex
Old Jul 6, 2006 | 07:58 PM
okbeast's Avatar
Default Brake adjustment on 400ex
I need to tighten my rear brake and had it all apart but couldn't figure out how to actually tighten it. Can anyone helpe me out? Thanks in advance!
Old Jul 6, 2006 | 09:24 PM
oldturtle's Avatar
The rear parking brake has two adjustments. The left hand lever cable is adjusted by loosening the round knurled lock nut and then turning out the adjuster. The rear adjuster is adjusted by loosening the hex lock nut and turning in the adjuster bolt. The rear brake foot pedal height is adjusted by loosening the lock nut below master cylinder and turning adj bolt. If all this does not give you plenty of brake then you may have air in system and need a flush/bleed.
Old Jul 7, 2006 | 03:13 AM
okbeast's Avatar
I'm looking to get more rear brake from the pedal, so I need to adjust it around where the pedal is? Thanks for the info too!!
Reactant
Mar 30, 2022 02:08 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
willday08111217@gmail.com
Aug 1, 2015 04:05 AM
metal249
Jul 28, 2015 09:35 AM
