Code
Old Jul 8, 2006 | 06:30 PM
nfox's Avatar
Default Code
Hello there i was up at trimont minnesota today and watched there mud run and rode there trails at elm creek, lots of fun after the rain. Before i left i got a check engine light and a code 51, what do i need to look for to solve this problem? When the check engine light comes on the it spit and sputter at low rpm and go away at 4500 rpm and above, i have good fuel pressure and a new fuel filter. Any help would be greatful!!!!
Old Jul 8, 2006 | 06:38 PM
Chevelle454's Avatar
Default Code
i think u can find out what the codes mean in the manual. if it dosent say what they mean just call polaris and ask them.
Old Jul 9, 2006 | 12:14 PM
JjEjFjf's Avatar
Default Code
I have an 06 800 and the code 51 has to do with injector 1 . Its either Open load , short circuit to ground or short circuit to battery.
Old Jul 9, 2006 | 03:10 PM
JCDEYO25's Avatar
Default Code
nfox....
Check your coil gound...
John
Old Jul 13, 2006 | 07:08 PM
nfox's Avatar
Default Code
I cleaned up all of the grounds on the atv and added a extra ground from the coil to the frame and i still get a slight miss and a code 51, any other suggestions or ideas?
Old Jul 22, 2006 | 05:14 PM
nfox's Avatar
Default Code
I just ordered a new coil and plug wires to see if this cures my problem. Any other suggestions to check or look at? I cleaned all of my grounds and fuses and added a ground strap to the coil and when it gets warmed up it starts to miss and i get a code 51 still, it only happens for a few seconds and goes away for a while and starts over.
Sw00p
Sep 24, 2015 02:50 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
