Sportsman 400 no spark
Old Jul 8, 2006 | 08:46 PM
sammydogs64's Avatar
Default Sportsman 400 no spark
My buddy has a 2003 sportsman 400 and the he is getting no spark. I removed the pull start cover and cleaned the pickup but still nothing. Is there a common faild component that might cuase this?
Old Jul 8, 2006 | 09:07 PM
skidoofan's Avatar
I have seen on the 500 sportsmans 2003 -2004 that the sparkplug wire gets pinched between the frame and gas tank. the wire must be rerouted. If thats your problem I dont know but it would be worth checking out.
Old Jul 9, 2006 | 05:48 PM
I checked that, when I was diagosing the problem, and the routing looked fine
Old Jul 10, 2006 | 11:52 AM
duffus's Avatar
check the coil (should be on the frame near the gas tank, or under the front cab on the older units) and make sure the connections are clean and still plugged in-- is the sparkplug boot threaded ontothe wire fully? Did this suddenly happen or did it not start after setting for a few weeks?
Old Jul 10, 2006 | 05:44 PM
I believe it sat for a day or two. He shredded a belt, changed the belt, took it out for a ride around the block then put it away for the day or two, then nothing no spark
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
