1998 xplorer 4X4 need help
Old Jul 8, 2006 | 10:50 PM
shanae's Avatar
Default 1998 xplorer 4X4 need help
i have a 1998 xplorer, has week spark i have checked, cleaned carb. changed fuel, new plug and still have week spark any sug?
Old Jul 8, 2006 | 10:56 PM
thedoc's Avatar
not unusual for a Weekend Warrior to have a Week spark - lol
Old Jul 9, 2006 | 12:28 AM
ncriderforks's Avatar
How did you check for a weak spark? 9 times out of 10, either you have fire or you don't. If it is a weak spark issue, it could be anything from a ground issue with the coil, to the trigger pulse generator not sending enough voltage to the coil, bad end cap, bad coil itself, or an issue with a ground at some other point. If you don't have a way of testing fire, I hate to say this but do it the old fashon way. Grab hold of that thing and if you can stand it, I would go farther into the spark being weak. If it shocks the pure crap out of you, then I'd be looking at timing or crank seals, or even compression. I know it sounds dumb, but you won't be questioning how strong the spark is. Not very mechanical to say but if you don't have the book in front of you to check, then its hard to just guess. Is it a 300 or 400? I have some books on them both. Let me know and i'll give you the test procedures for checking the tpg, coil and cap resistance.
Old Jul 9, 2006 | 02:21 AM
shanae's Avatar
thank you very much, if you could help me with the coil resistance, i was able to hold on to the spark not much there, it is a 400, i need the procedure for the timing
Old Jul 9, 2006 | 04:09 AM
thedoc's Avatar
so I assume you are holding spark lead while turning over engine with electric starter - correct?
if so the battery will be down at say 6 to 8 volts only so would not expect a really good spark until engine fires [when it will go up to about 14 volts]
is the problem that engine wont start at all? - and you are assuming it is the spark or have you somehow measured the spark and confirmed it is the problem?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Slagpolaris
Sep 5, 2015 09:41 PM
