sportman speedometer and 4wd dont work
Old Jul 10, 2006 | 02:33 AM
AtvJunkie2000's Avatar
Default sportman speedometer and 4wd dont work
I have a 2000 polsris sportsman 500 HO that has not been run for a couple months, I recently got it out and now the speedometer, odometer,and 4wd do not work. I can not figure out what could have happened to make this happen. I asked to dealer in our area, and they told me to check a couple of fuses, so i didm, but they were fine. Another dealer told me to replace the speedometer and that SHOULD take care of the problem. I don't want to spend $350 on a new speedometer and that not fix the problem. Is there anyone out there that has had this problem or has an idea what else could have caused this? Any help would be appriciated.
Old Jul 10, 2006 | 02:44 AM
duffus's Avatar
do your headlights work? does the electric starter work?
if the headlights & ES are out, check the relays. They will be in a black "pocket" under the front cab/cowl and near the solenoid and battery in the rear. The 2000 model had some sloppy wiring compared to the newer models so they might be difficult to locate. if one of these are tripped, none of the electrical equipment will work. There are 2 or 3 on the 2000 model units (someone correct me if i'm wrong)
Old Jul 10, 2006 | 03:35 AM
Both the headlights and the electrical starter work fine. Thats what I am having the problem with. The dealer gave me a copy of the electrical scematic of teh machine, and the think everything is ok with that as far as i can see.
Old Jul 12, 2006 | 02:35 AM
Both the haedlights and es are fine. The dealer gave me a copy of the electrical scematic, so far what we've checked has been fine.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
