1996 Xplorer 400 Locked 4WD
Old Jul 16, 2006 | 05:36 PM
DiamondSCattleCo's Avatar
Default 1996 Xplorer 400 Locked 4WD
I have a 1996 Xplorer 400 that I use primarily for ranching duty. Its not a bad unit, but the On-Demand 4WD drives me nuts when I get into deep mud, deep snow, or I'm trying to crawl downed trees. It acts like an open diff and sends power to the tire least in need of it. I've read about spinning the tires in 4WD reverse and it does seem to be locked up after doing this, however I would simply like to change the system over to a fully locked 4WD. Anyone know how I might accomplish this?
Thanks in advance.
Rod
Old Jul 16, 2006 | 06:29 PM
cornbread2's Avatar
You must have something wrong with one of your hubs. Both front wheels should pull at all times when it is in 4wd.
Old Jul 16, 2006 | 10:38 PM
ftwflh's Avatar
When was the last time you change hub fluid ?And if it was cleaned out before new put in?
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
chewy78
Sep 8, 2015 10:37 AM
