How to make wheel spacers?
Old Jul 19, 2006 | 10:47 AM
Neuromax's Avatar
Default How to make wheel spacers
I have seen several posts talking about making wheel spacers but can't find any info on HOW to make them.
I have a 2000 Eton 50 that I would like to make just a few inches wider. I can't find any kits online for this model and no cross reference guids.
thanks.
Old Jul 19, 2006 | 12:03 PM
LT80's Avatar
LT80 Expert
Default How to make wheel spacers?
I use 1" round aluminum and drill a hole in it. The hard part is getting them exact in length.
I knock out the stock studs and put long bolts thru. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jul 19, 2006 | 12:56 PM
Neuromax's Avatar
thats a great idea!!!!
Old Jul 23, 2006 | 08:55 PM
bananaman's Avatar
Is this suitable for a full sized quad as well?
Old Jul 23, 2006 | 10:18 PM
hondabuster's Avatar
I know they make stud extenders, which add 1 or 2 inches, but im not sure id use them on a full size quad...especially if it were a 4x4. The 1" rod with a hole is probably ok on the fronts of a 2x4, and some people just use washers. As long as it goes together tight, and stays tight, its no bettter or worse than the full spacers.
You might be better off, starting with 1" thick aluminum bar stock, cutting off what you need, and adding a hole. Then at least the thickness of all 4 would be the same, with in .001".
Old Jul 24, 2006 | 12:12 AM
oldyeller's Avatar
If you are looking for a spacer all you need is one with 4X110 bolt pattern.This is a very common size rear pattern for alot of mini's and full size sport atv's such as Honda EX and Suzuki,kawi just to name a few.Any of the mini atv racing guys should have them such as Hetrick's,WRH racing,Koolkidz etc.
Old Jul 24, 2006 | 11:18 AM
LT80's Avatar
LT80 Expert
"You might be better off, starting with 1" thick aluminum bar stock, cutting off what you need, and adding a hole. Then at least the thickness of all 4 would be the same, with in .001". "
HEY, that's a good idea!! Wonder where you heard that.[img]i/expressions/face-icon-small-tongue.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 24, 2006 | 02:18 PM
Totally different. Your idea was for 1" round stock, saw cut to length. Which can be very difficult to get all 4 the same thickness on the mounting surfaces.
Im thinking of flat stock, which is 1 inch thick, and just saw cutting the the sides,( which mean nothing,) leaving the mounting faces as stock, which wont vary by more than a thou. This way they can be made with out any special tools, other than a drill motor , drill bit, and hack saw,,,and still be totally accurate where it counts.
Ill admit its similar, but the results arent.
Old Jul 24, 2006 | 03:21 PM
LT80's Avatar
LT80 Expert
I understand now. [img]i/expressions/face-icon-small-smile.gif[/img]
My bad. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 24, 2006 | 03:57 PM
No biggie, Your method will leave a better looking spacer, but the flat stock doesnt require much skill, to produce an accurate spacer...but might look a bit shabby.
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
cSchwartz
Jul 12, 2015 07:42 PM
yambam13
Jul 4, 2015 01:49 PM
