Iz my tranny gone? or what?
Ok i have a 250x with and big bore kit, higher compression piston, bigger intake and exhaust, FMF pipe and header, New timing chain,ported and polished head (Stage 1 MX port), new chain tentioner proformance cam and valves, and i am wondering if all this work has toasted my tranny?? Oh i also have a new Barnett clutch instaled, The fourwheeler shifts fine in 1st 2nd and 3rd but when i get it higher up it reves Extreamly high!!! and if i let off of it it acts like it catches and then goes... but if i get back on the gas it does the same thing... well it is kinda slower than it was like taking off wise and it acts like its held back... it has just stared doing this.. i just put my engine back in the bike after some resent polishing the side cases and everything like that.. the clutch Iz way out like you bairly have to press it for it to grab and u switch.. so if u could help me out that would be great! Oh in the winter if i can get by im going to put all new gears in it and a 12.7mm stroker crank, and get a new Cam (sparks racing cam) and replace the piston and get a new timing chain.. so i hope i described it good enouf if u can help me out that would be great!
I replaced all the plates and everything upgraded springs and friction disks and stuff like that.. it iz the sto clutch basket... i didnt replace it b/c it was fine no cracks or damaged places..
Are you sure that the basket wasn't grooved anywhere? I'd be really surprised if it wasn't after 18 years. My 86 had grooves on every finger and the clutch operated just like you described. I filed the grooves out, put it back together and it works fine now.
iz it supposed to have grooves on the out side of hte basket?? it had those when i took the side case off 3 days ago but they were on the outside of the basket im going to adjust the clutch when i get the bike to the house this evening and see if that helps any... any other sugjestions?? so where was your groves at?? they were pretty ruff looking.. so idk and it was all the way around the clutch basket...
That's exactly where they SHOULDN'T be! Could very well be the cause of your problem if they are bad enough. I used a fine file all the way around the outside of the basket, cleaned and reinstalled. Check out this auction, this is what the outside of the fingers should look like. Get rid of the grooves or replace the basket!
http://cgi.ebay.com/ebaymotors/HONDA...7626QQihZ005QQ
categoryZ43977QQrdZ1QQcmdZViewItem
Logan Collins
Sep 5, 2015 08:03 PM
