Polaris Predator 90 Problems
Old Jul 20, 2006 | 12:18 PM
dagman's Avatar
Default Polaris Predator 90 Problems
My 2002 predator 90 bogs down and backfires when throttle is 3/4 to full, but runs fine off the line to 1/2 throttle. I've changed the fuel filter, checked the spark plug (beer bottle brown), and I have drained the fuel and oil tanks. When I remove the filter and spray carb cleaner in it it dies.
Any suggestions??
Old Jul 20, 2006 | 03:52 PM
Lak's Avatar
Lak
I just got my sons polaris back from the shop, doin' the same thing. They took the carb right off and cleaned it. Said there was varish{old gas] on the side and the needle had some dirt on it. runs great now!
Old Jul 20, 2006 | 05:59 PM
spike99's Avatar
If you can, remove the carb and take to a motocross/ATV shop. They will completely disassemble and clean it out with special solutions. Also, install new gas. Natural condension creates water in the gas. This sometimes creates back-fires. As another idea, check its float level. I've heard the float adjustments on the 16mm carbs are very sensitive. If above 1/2 throttle and starts back firing, it could mean improper air mixture, from improper set float level.
If you haven't done so already, remove its factory RPM clip. Only set this RPM range using its throttle adjustment screw. I've read in the Polaris manual that if this Metal Clip is installed and its throttle control screw is set higher, it will (by default) get improper gas/airflow mixture. Thus, some backfires when "trying" to go above 1/2 throttle.
Hope this helps as well...
Old Jul 20, 2006 | 06:20 PM
RacinJason's Avatar
I see a lot of issues directly relasted to the elec choke. We install a manual choke mechanism on most of the quads. Its available from Polaris as a kit and easy to install
Old Jul 20, 2006 | 07:10 PM
knauf's Avatar
3/4 to full throtle bogs and backfires. Sounds like a clogged main jet. Pull the float bowl and check to see if it is clogged.
Old Jul 21, 2006 | 01:23 AM
Fastestdad's Avatar
I agree with the other guys sounds like clogged carb mainjet or passage, fuel filter. Even float seat clogged possibly.
Old Jul 21, 2006 | 11:25 AM
dagman's Avatar
I pulled the carb, took it apart and cleaned it. I was kind of hesitant at first since it's the 1st time in my life I've ever pulled a carb and cleaned it. It wasn't near as difficult as I imagined. Pulling off all the plastic was the hard part. It runs better than ever now. Thanks for the advice!! I cleaned the whole thing with gasoline and a new paint brush then sprayed it all clean with carb cleaner. Should I have put in new gaskets or seals? I just screwed it all back together without any type of adheasive or sealant. Thanks again.
Old Jul 21, 2006 | 12:17 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Originally posted by: dagman Should I have put in new gaskets or seals? I just screwed it all back together without any type of adheasive or sealant. Thanks again.
Nope. You did just fine.
cbcole02
Sep 7, 2015 06:16 AM
Berjr
Jun 15, 2015 04:41 PM
Predator_500
Jun 13, 2015 03:01 PM
TJM
Jun 11, 2015 01:28 PM
Falcon150
May 25, 2015 05:36 AM
