keihin pwk 39
Old Jul 21, 2006 | 11:53 AM
bentstuff's Avatar
Default keihin pwk 39
i have a keihin pwk in my 2002 scrambler 2 stroke. after 2 days of sitting it will not start unless i pull the top off the carb and prime it with a little fuel. i checked the float and valve-it seals. does anyone know why it may be doing this? or anyone know of a primer kit for this model? thanks so much for any help
Old Jul 21, 2006 | 12:32 PM
duneaholic's Avatar
Check you choke adjustment...it may not be adjusted right and not letting fuel into the starting circuit.
Old Jul 21, 2006 | 01:09 PM
bentstuff's Avatar
the choke never did work that great-i am only able to pull the cable out about 3/4 of an inch. i looked at it several times and was never able to get any more out of it
Old Jul 28, 2006 | 11:33 PM
scramblered's Avatar
yes,the race version of the pwk have a pull choke button,at the left side of the carb,you have to remove your seat,
at warm up to choke it 2-3 time then it's gone,alot easier to use and less cable to steer at the handlebars,the only cable to use then is the trigger,i used both version and the race version pwk is more performance oriented as well
and lighter.
Old Aug 2, 2006 | 08:24 PM
bentstuff's Avatar
any idea where i could find one of those manual pull chokes for pwk 39?
Old Aug 3, 2006 | 01:56 AM
conig's Avatar
a 98 kawaski kx250 uses the same carb you canget one from sudco.
Old Aug 4, 2006 | 12:03 AM
16polaris's Avatar
Just go to www.hpd-inc.com and buy the correct carb. It will be jetted close to the correct size and made just for your model.
slowgsxr97
Mar 18, 2022 03:40 AM
Dabears1983
Technical and How-To Articles
Jul 1, 2015 07:51 PM
derbyking
Aug 29, 2004 10:44 PM
BrokenLimbs
Jul 17, 2001 06:42 PM
nightlife7810
Oct 17, 2000 04:36 PM
