piston and cam for 95 wolverine
Old Nov 28, 2000 | 08:36 PM
macgiver's Avatar
what is a good lift and duration cam for good low and midrange tork, that will not hurt my top end. also what compresion piston is good to go with it.i want to be able to spin 25 inch tall tires in mud without a problem, and still be able to run with the 23 inch tires if i want. i just ordered the e-searies pipe, jet kit and tork stuffer. any help would be great
Old Nov 30, 2000 | 06:58 AM
macgiver's Avatar
come on HELP
Old Nov 30, 2000 | 10:59 AM
Harold's Avatar
go to web cams site to get the skinny on cams or call highlifter!!!
Old Nov 30, 2000 | 04:18 PM
RaPtOrRiDr01's Avatar
Go to www.Powroll.com, they make any size cams, valve springs and i think a big bore kit also.Their prices are great! Check it out!!!
Old Nov 30, 2000 | 07:58 PM
Labs's Avatar
I have a 00 wolverine. I went thru Alba (they are in your dirtwheels magizine) I put a 10.750 to 1 Piston in I also bored .02 over. I believe a .380 cam.Also heavier valve springs with titanium keepers, a FMF muffler, same size carb but with a higher flow rate and rejetted, drilled air box, K&N airfilter. I can lift the front end off the ground going thru the first 3 gears with a 40lb winch on the front. Cost was about $1100.00 with out labor on bike. Call Alba for help.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
