Grizzly Sputtering from dead stop to full throttle.
Old Jul 25, 2006 | 10:04 PM
big4x4's Avatar
Default Grizzly Sputtering from dead stop to full throttle.
Just got a grizz and the only problem i can see is that when I am at a dead stop and floor it, it will sputter for 2-3 seconds before taking off. What could be the problem? After 4 mph, the thing takes off like it should! Input will be greatly appreciated
Old Jul 26, 2006 | 11:32 AM
GlennJ's Avatar
Sounds like a jetting issue. Any mods or is the quad mostly stock? How does it start and idle?
Old Jul 26, 2006 | 11:44 AM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
If you havn't changed anything on it and it just started doing it, you could have a clogged fuel filter, dirt in the bowl, got a batch of bad gas, a pinched breather or fuel line.
More information is needed to be able to help you. =]
Old Jul 26, 2006 | 02:06 PM
big4x4's Avatar
The bike is totally stock. I will drive it more today and see.
Old Jul 26, 2006 | 02:47 PM
big4x4's Avatar
Another thing, when i started it cold this morning, the engine has to heat up before it will idle without dying
Old Jul 26, 2006 | 03:01 PM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
Take it back to the dealer and tell'em you didn't spend that kind of money for a 3 second delay. It's a jetting issuie/fuel screw needs fine adjustment. They should be able to fix it in a matter of a few minuites.
Old Jul 27, 2006 | 03:08 AM
big4x4's Avatar
If it only takes minutes, i would rather save the trip and learn to do it myself. How would i check the jetting / adjust the fuel screw. I gotta learn sometime ; )
Old Jul 27, 2006 | 10:45 AM
Hebs's Avatar
The cold starting and engine warm up can be normal... but if it takes a while... then the valves might be sticking a bit... This quad is brand new?
Old Jul 27, 2006 | 02:13 PM
JLsparky7's Avatar
Does it idle fine once its heated up? Im thinkin your idle is a lil low. My banshee was the same way from the stealership.
Old Jul 27, 2006 | 02:40 PM
big4x4's Avatar
Yea, it idles great once it's hot
greg74
Sep 10, 2019 03:03 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Jul 28, 2015 12:12 PM
bpegram84
Jul 22, 2015 08:15 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
