LT 80 fuel out of exhaust
Old Jul 26, 2006 | 12:29 AM
jeddhunter's Avatar
Default LT 80 fuel out of exhaust
Im a carpenter not a mechanic so i could use some help? the electric start would just click at the relay so i thought the starter or relay were bad. i just learned about the reset switch under the fender, so i reset it and it and hit the start button. It turned over then fuel leaked out where the exhaust bolts to the motor. I checked the fuel shutoff it was on. It is leaking quite a bit of fuel when i crank it over. It cranks until it kicks the reset switch under the right fender. The exhaust gasket on the pipe is shot and a bolt is missing from the flange. Thats why i can see the gas drizzling out by the motor. Thankful for the replies!!
Old Jul 27, 2006 | 01:46 PM
Bowls's Avatar
Sounds like your fuel switch is leaking. You may have a bottom end full of fuel. I would take the pipe off and stand it up on end to verify/drain the bottom end of gas.
Old Jul 27, 2006 | 03:54 PM
Rudedog's Avatar
It could be the fuel petcock.. and or it could be the carb float is stuck. Pull the plug and crank it around to clear the cylinder and change the plug as it may be fuel fouled. If the cylinder is full of fuel, when you crank it around it might be trying to compress the mixture, can't and so over working the starter which could be causing popping the reset? As the petcock is vacuum, no fuel should be going to the carb when it's set to ON (check). As for the carb you can tap the bowl a few times to see if you can dislodge it.
Rude Dog
Old Jul 27, 2006 | 06:42 PM
Rzoomer's Avatar
Yep sounds like the float stuck.. stand it on the end and let the gas drain out and rebuild the carb. Try again.
Old Mar 29, 2007 | 04:25 PM
Kevdawg62's Avatar
Hey This is my first post so i dont know all the slang and lingo but I do know alittle about the lt80. When you say shee petcock is that a brand or the actual petcock for a ban"shee"? the vaccum hose from the stock petcock goes to which hole on the carb? there are two to choose from and I am not sure which one it is.
Thanks
Old Mar 30, 2007 | 05:09 PM
LT80's Avatar
LT80 Expert
vaccum hole is closest to the motor.
The front hole is the vent. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 7, 2007 | 12:57 AM
billyboys's Avatar
My machine did the same thing ...I cleaned carb 3 times ...but didnt clean pilot jet....When I cleaned pilot jet it solved the problem.....
slowgsxr97
Mar 18, 2022 03:40 AM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
bpegram84
Jul 22, 2015 08:15 AM
