banshee shifter
what can you do to help my little shee shift better. its just hard to shift sometimes, i guess ive got use to my kfx. you just think about shifting and it just happens, you have to have your foot just right under the shifter to pull mine.
I know someone who took the shifter off, and then put it back on but a couple of splines up, so the shifter sat up higher and he did not have to put his foot right under it.. Not sure if that is your problem, if not then maybe change your oil.
ive been thinking of getting a shift kit for it. has anyone put 1 on?? are they a pain or not really to bad??going to put some diffrent oil in tommarow and see if that helps any. thanks again.
put some MOTUL gear oil in this morning,and moved my shifter closer to the case. it shifted alot better!! my shee's a 98 so it will probably be getting a make over this winter. i bought it 4 $500 last feb, frame ,motor and alot of pieces. ive only had it out riding it 2 or three times. its pretty strong for a $500 bike. thanks for the help.
Steeldon
Sep 9, 2015 09:38 AM
Jul 7, 2015 11:00 PM
