What is the correct premix ratio to run with 110 octane?
Old Aug 1, 2006 | 05:47 PM
rdnred's Avatar
Default What is the correct premix ratio to run with 110 octane?
I just recently rebulit my 86 250R, it is bored .80 over, and has a 21cc cool dome head by Paul Turner. I had been running 93 octane previously but a local shop told me i needed to run 75% 110 and 25% 93 to keep from having detonation. My question is what ratio do i need to mix the oil at, i had been doing 50:1? And was just curious as to whether or not the ratio would change or not. Thanks
Old Aug 1, 2006 | 05:58 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Well, it depends on what oil your using and what your machine is jetted for. I'd say you would still run 50:1, maybe try 40:1 to be a little safer. If it fouls a plug, go back to 50:1.
Old Aug 1, 2006 | 07:04 PM
rdnred's Avatar
Not sure of the jetting without looking. The oil i am using is Silkolene.
Old Aug 2, 2006 | 12:04 AM
Boomer2's Avatar
If 50 to 1 worked before it should be okay. Espeically if the oil is synthetic, I've never heard of the brand you are using. The higher octane should make it run cooler, so you wouldn't need exta oil to cool the cylinder.
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
2many2ride
Sep 27, 2015 04:35 AM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
