fmf megamax
Old Aug 5, 2006 | 06:59 PM
Wolverine350rider's Avatar
Default fmf megamax
im ordering one for my wolvie, anything i need to know?
i will re-jet because im getting a cfm performance airbox too.
thanks
Old Aug 5, 2006 | 08:35 PM
recon99's Avatar
Default fmf megamax
STOP!!!! Don't order it!!!! TOTAL JUNK!!! I had one on my honda recon, it was a terrible exhaust, i'd much rather have the stock one. It gave me so much trouble that I will never buy another FMF product as long as I live. They use steel fasteners to hold everything together, and as everyone knows, steel rusts. So after you ride threw water a few times everything rusts solid and the only way to get the thing apart to re-tune it or repack it is to drill everything out and start over. And of course with my recon FMF didn't even incorporate a way to seal the joint between the header and silencer properly, no clamps, gaskets. Nothing, so I had to rig up my own way with some thin sheet metal and hose clamps. I don't know if the wolvy's would be the same way, but either way fmf is still pretty crappy.
Old Aug 5, 2006 | 08:38 PM
Default fmf megamax
what about the powerline?
Old Aug 5, 2006 | 08:44 PM
recon99's Avatar
Default fmf megamax
I don't have much experience with the powerline, but i'm totally against fmf 4 stroke exhaust in general no matter which model it is. If you're looking for max power gains look somewhere else, the only thing fmf has going for them is they're usually quieter than the competition.
Old Aug 5, 2006 | 08:47 PM
Default fmf megamax
thanks for the help
My cuzin has the FMF Q on his warrior. does that have the same steel setup like on the megamax? his pipe looks new and its over a year old
Old Aug 5, 2006 | 08:58 PM
recon99's Avatar
Default fmf megamax
The megamax is an old design, and I woud hope that fmf would have corrected the problem for the newer ones but i don't really know. It's not actually all the fasteners that rust up (the ones around the side of the can are stainless to make it look good) but the nuts welded inside the can are steel, and I believe the end cap screws were also regular steel. It may not seem like a big deal that the nuts inside the can get rusty, but the problem is that they get seized onto the screw and when you put some torque on them to break them loose most of the time the welds break instead, and the nut spins freely inside the can.
Old Aug 5, 2006 | 11:27 PM
silent101's Avatar
Default fmf megamax
ya dont buy FMF I have a 2001 400EX With a powercore 4 and Its 3 years old and its falling appart. The spark arestor fell out of the back and the end cap is about to crack off. Also the seal witch seals the slip on to the header has dry roted resaulting in a air leak. I Also have on a airbox and pro flow k&n and the air box welds are breaking all the time and the battry flops around brakeing the cable all the time. Also the battry will hit the airfilter and keep tearing holes in the filter and pre filter. Some times it will even push backward and dislodge the intake boot from the carb. Also I have to clean the airfliter every hour of use because it will get so dusty and the quad will run worse than stock. I am going to change all this back to stock soon since I bought the quad with these. I dont why you would ever buy this junk all for 2 to 3 HP. And not to mention it is so loud the nabor has caled the police before. Do not Buy fmf or a airbox. If you have to modify get a different pipe and remove lid on stock air box
Marco
Jul 23, 2003 04:12 PM
300exwanter
Apr 23, 2001 05:09 PM
Recondude
Jan 9, 2001 11:51 PM
boz84
Sep 11, 2000 07:54 PM
99_warrior_350
Dec 11, 1999 12:27 AM
