aux. lights for yfz
Old Aug 7, 2006 | 10:02 PM
lancec2c30's Avatar
Default aux. lights for yfz
I wanted to install a set of aux lights on my yfz, now I have a set of 55 watt driving lights for a vehcile. now I was thinking of mounting a single one in the center. this is becuase there is a hole drilled in a brace across the center of the fram where I can easily install the light.
But my question is will the battery and eletrical system support a 55watt light from a vehcile or not??
thanks,
Lance
Old Aug 8, 2006 | 01:23 AM
lancec2c30's Avatar
*bump*
Old Aug 8, 2006 | 03:49 PM
JLsparky7's Avatar
Check the specs on yamahas website, i think there are other numbers that are significant other than the wattage.
Old Aug 8, 2006 | 09:09 PM
squeege's Avatar
I think you can squeeze about 40 watts b4 screwing anything up, but don't quote me on this
Old Aug 9, 2006 | 01:15 AM
lancec2c30's Avatar
you mean per light correct? Becuase the lights that come from the factory are 35 watts apiece.
And if I wanted to install a set of 55 watt lights, what oversized stator would I need? and could you give me a estimated price on it?
Old Aug 9, 2006 | 03:04 PM
squeege's Avatar
I ment another 40 watts..cause yammi make 55w upgrade bulbs that would be 40w above factory 35w bulbs.....also people are running heated handgrips that pull about 40w without problems......so 40w over stock seems OK....
Old Aug 9, 2006 | 04:15 PM
lancec2c30's Avatar
o ok, So it wouldnt be a good idea to use the light then.
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
