Problem with 2/4 wheel selectable drive
Old Aug 10, 2006 | 05:24 PM
03FM450's Avatar
Default Problem with 2/4 wheel selectable drive
I've got a 2003 TRX 450 FM that doesn't go on 4 wheel drive anymore. The 4 wheel indicator doesn't light up when the ignition is turned on, only when the machine is started it lights up, even then it doesn't blink to show that there is a problem. Did any of you have this same problem before and fixed it? If so how? Thanks.
Old Aug 10, 2006 | 05:46 PM
hondabuster's Avatar
Are all the fuses good?
Old Aug 10, 2006 | 06:39 PM
03FM450's Avatar
Yes, all the fuses are good.
Old Aug 10, 2006 | 09:26 PM
Rinman's Avatar
I would start tracing wires. It sounds like you have power at the switch but its not going anywhere. Check to make sure all connections are clean and plugged in. It maybe a broken wire.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Stillonit
Jun 18, 2015 11:23 AM
volsgo30
Jun 4, 2015 06:07 PM
kevbowe
Jun 1, 2015 01:17 AM
