Sport Quads Discussions on sport quads.
question on changing oil in z400
Old Aug 10, 2006 | 06:41 PM
brandons04's Avatar
Default question on changing oil in z400
Ok i dont know if this is a dumb question or not but when i change my oil i just drain the oil tank change filter and fill the tank back up, is that it or do you put the oil in the crank case, that bolt on the right side of motor just below filter housing because some peopl say that is where they put it. WHat is the correct way, thanks
Old Aug 10, 2006 | 06:52 PM
1of4Horsemen's Avatar
Pale Rider
With my goldfish shorts swimmin' around my toes.
Drain the oil tank, drain the crank case, the nut is on the bottom of the crank case not the side. Replace the old filter with a new one. Fill up the oil tank with the required amount of oil.
Start the engine let the oil circulate through the engine and filter. Recheck oil level on dipstick.
Old Aug 11, 2006 | 09:29 AM
Lefty31's Avatar
Make sure you put in the new filter the way the old one came out....otherwise you won't get any oil to the motor and it'll fry. figured this would be a good piece of info. [img]i/expressions/face-icon-small-happy.gif[/img] good luck it's easy man
Old Aug 11, 2006 | 10:42 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Yup, crakcase bolt is on the BOTTOM of the engine. And like they said, be sure the filter is in the right way. Some good info on oils: http://www.thumperfaq.com/oil.htm
Honda put the 400EX cranckase bolt on the side......dumb idea! Makes a huge mess if you have a skid plate.
Old Aug 11, 2006 | 10:45 AM
scootergptx's Avatar
Supersock
Hired Gun!
Don't forget to put the drain plug back in. [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 11, 2006 | 11:26 AM
brandons04's Avatar
Ok the oil filter is supposed to go with the bigger hole in first toward the motor and the small one out, just wondering because when i changed my oil the filter that was in it to start with looked a little different than the one i got from the dealer. The crank case bolt is the one on the bottom left side of the motor where the little hole in the factory plastic skid plate is, let me know if that is the one. thanks for all the info
Old Aug 11, 2006 | 12:22 PM
Supersock
Hired Gun!
An owners manual would be a good idea.
Kyle5050
Dec 13, 2019 04:25 AM
MNatv89
Aug 10, 2015 02:20 PM
toonces
Aug 5, 2015 05:55 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
