ds650 backfire porblem
Old Aug 10, 2006 | 06:44 PM
bombrider04's Avatar
Default ds650 backfire porblem
Hey guys I need your opinion on what you think this could be...I have been having a problem with my ds 650 when I run it for a little while and then shut it off it begins to backfire...I thought it had to do with my carb/coolant so today I put in engine ice and it does make a difference but it is still backfiring only when shutting it off...I have an alba racing full system with stage 3 jets and no airbox lid with a K&N filter...So after I put in the new antifreeze and ran it for a while I was hoping I would see a difference but no so I messed with my pilot jet to see if I could get any better response and it only would make it backfire at low rpms...my plugs have a white tip on them and are black on the porcelin...I put a newer stock cdi in as my old one went bad a while ago do you think this could be the problem,pilot or main jet,or something else. Any help would be appreciated thanks.Brett
Old Aug 10, 2006 | 08:29 PM
nathanpri08's Avatar
After you shut the ds off?Is it loud because my ds,foreman,sportsman all backfire after shuting off.I think its acces gas or somting in the exhaust.Mine just a little blip.But its normal to me, not noticible or anything really.
Old Aug 10, 2006 | 08:32 PM
nah its pretty loud then I tried putting on my stock gas cap and tried it then and it went away a little but I could still hear it...I had a billet gas cap on there and am running a 185 main jet...I think that the problem is that the billet one doesn't ventillate and since I run it for a long time it builds up and becomes air tight and it is letting all of the compression out of the system so I believe that is the problem can anyone vouch for that. Should I be running a different main jet lower I have all the way up to a 200 some guy gave me extra jets when I got the bike so please someone help. It could just be the weather but i want to atleast find out why its happening.
Old Aug 10, 2006 | 09:09 PM
I dont know man.Hopefully some more expirienced people could help you out with the problem.
Old Aug 10, 2006 | 09:15 PM
cloftis's Avatar
unless you changed your stock gas tank changing your gas cap will not do anyrthing!! the ds stock gas tank is vented their is a hose attached to the tank!!
Old Aug 11, 2006 | 12:08 AM
yea I know its on the right side i gotta check that tom and see if its kinked or not...if the tip of my plug is white what do you think I should do i adjusted the pilot jet to see if it would help and all that did was make it backfire at low rpms
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
