Power Commander Buttons
Old Aug 12, 2006 | 06:21 PM
Soccermike26's Avatar
Default Power Commander Buttons
When fine tuning with the button adjustments. How do you know if you need it leaner or richer? With me my top end feels like it doesnt pull as much as it did before the PC. how would I know which way to adjust that? Thanks
Old Aug 12, 2006 | 06:41 PM
bberck's Avatar
Well if you are running a PC map you are most likely a little rich. Most say there maps tend to be on the rich side. The only way to know for sure is a good ole fashion plug check. I have a custom map and I compared it to the one PC recommends for my set-up and mine is leaner across the entire map. I have done a plug check on mine and my plug looks real good. If you pull up your map on a computer you can lean the entire map or portions of it 1% at a time and try out different versions of your map, just save the new map under a new name. I have a map thats about 2% leaner, I run when I have to use my Spark Arrestor.
Old Aug 12, 2006 | 06:47 PM
I'll give it a try...thanks
Old Aug 12, 2006 | 06:50 PM
When you say that you made a map that is 2% leaner accross the board, do you mean that you went through every cell and dropped that number value by two?
Old Aug 12, 2006 | 07:00 PM
RaptorRandy27's Avatar
No, you can highlight the whole column or whole map and then page down to lean it out by 1% at a time.
Each click on the page down key is 1% try it with a copy of your map to get the hang of whats happening when you do it.
Old Aug 12, 2006 | 07:15 PM
bberck's Avatar
What Randy said [img]i/expressions/face-icon-small-smile.gif[/img]
And on my SA map I didnt lean the entire map I started at I beleive it was 2500 rpm up to 8 or 9000 rpm. The values under 2500 where mainly at 0 so I started on the rpm range that my map had changes at almost every throttle postion which was 2500 on mine. Then after 9000 rpm they where at 0 also so stopped there, but you really should have a 700r that high in RPM's anyway they fall off around 6500 RPM's.
Old Aug 12, 2006 | 07:37 PM
wow....there is more to this thing than I thought. I almost thought I wasted $300. Thanks guys. Can I take my bike to a shop and have them dyno tune with this?
Old Aug 12, 2006 | 07:41 PM
bberck's Avatar
Yes if they are set-up for it. You can go to Power Commaders website for a list of shops that can make you a custom map for your quad. They have them all over the country. Not sure what something like that would cost though. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 12, 2006 | 07:57 PM
In case you were wondering...A Dynotune around here costs about $250
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Gtsordo
Jul 22, 2015 01:27 PM
Chuck188
Jul 17, 2015 02:45 PM
Scottma518
Jul 10, 2015 12:42 AM
tweeder
Jul 5, 2015 01:57 PM
