Blaster carb - ghetto rigged
Old Aug 13, 2006 | 01:18 PM
300exStroked's Avatar
Default Blaster carb - ghetto rigged
01 blaster was having carb trouble.. when i would give it full throttle it would just bog wayyy down, still run.. but you were unable to move the bike it was so bad.. was told that it had the wrong mixture of fuel run through it before it came back from kentucky so i drained and cleaned the tank and plug.. decided to check out the main jet and i noticed that when i would go get the main jet out it would go all the way up and push the slide up .. didn't think that was right.. is there some kind of clip or something that holds that whole tube for the main jet down? .. couldn't figure out why it wouldn't stay down so i took a punch and a hammer and knocked down two of the edges to get it to stay down where it should be.. has this happened to anyone else before or does anyone know if there is a clip that goes on it to keep it in the proper position? Its ghetto rigged but it works just as good as new. thanks
Old Aug 13, 2006 | 04:05 PM
RickRitter's Avatar
You are missing a washer under the main jet . It takes a special one . Go see your dealer.
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 15, 2015 10:48 PM
joeyupton
Jul 14, 2015 11:51 AM
