Brake Light
Old Aug 13, 2006 | 11:22 PM
Lak's Avatar
Lak
Default Brake Light
Both my kids have 2001 Polaris scramblers,one 50cc and one 90cc. There brake light is now on all the time(except when the key is off)The 50cc was running without a running light but his brake light worked, now his brake light is on staedy as is the 90cc. I looked at the bulbs and both filaments seem okay? I checked the brake cable to make sure it is'nt to tight to cause this. Any ideas? Is there a brake light switch that could be gone? Thanks Jim.... [img]i/expressions/face-icon-small-confused.gif[/img]
Old Aug 14, 2006 | 12:10 AM
kartattack's Avatar
Default Brake Light
Look back about 4 pages for this thread.
Predator 90 Brake Light
http://forums.atvconnection.com/mess...did/497573.cfm
This might be your problem.
Old Aug 14, 2006 | 12:26 AM
Lak's Avatar
Lak
Default Brake Light
Thanks, I will check that out tommorow when the kids are gone. I will let ya know.
Old Aug 14, 2006 | 04:02 PM
Lak's Avatar
Lak
Default Brake Light
Thanks kartattack, that was the problem on both quads. Tha 90cc was bent,the 50cc I just took out and sprayed it with WD40. The only thing now is sometimes I have to wiggle the wires to get them started! Did I put something in wrong?Thanks Jim.......
Old Aug 14, 2006 | 09:56 PM
kartattack's Avatar
Default Brake Light
Lak:
I'm not sure how to explain this, but I think you put in the plastic thing that separates the wires/contacts incorrectly (I did this). The easy way is for the contact prongs (not the part that touches the pin that activates the light, but the two little legs that stick out onto the plastic separator) to go in the lower groove and that results in the pin not being able to touch the contactors. There is a notch with a saddle (hump) in it just above the lower groove and this is where the base prongs of the contacts have to ride for the pin to reliably make contact. I had to really put some pressure on the wires to get both contactor's prongs to reside in that second groove (with the hump). If it went back together really easy and the contactors don't protrude past the plastic separator, then that is your problem.
I am sure that is as clear as mud, but I think if you take it apart again, you'll see what I mean.
Old Aug 14, 2006 | 10:24 PM
Lak's Avatar
Lak
Default Brake Light
Thanks again pal, I will check this out tommorow. The part is about 20.00 each from the dealer. Hopefully I can figure it out. Kids were bummed that they couldn't start there quads tonight, but of course they dont understand the meaning of having there brake light working properly! And tell them to be patient while Dad tries to figure it out is like waiting for the moon to fall HA HA!! I will let you know what happens. Thanks again and I am sure I can get it.
Old Aug 18, 2006 | 12:17 AM
kartattack's Avatar
Default Brake Light
Any luck, Lak?
Old Aug 18, 2006 | 12:23 AM
Lak's Avatar
Lak
Default Brake Light
The 90cc seems to have been starting the last couple times okay. Busy with the kids the last couple days at camp. Gonna have a try this weekend.Very good explanation of what to do with the contacts and such. I think I know what you are talking about. I am going to print the reply grab a cold beer and give it a try. Will let ya know. Thanks again.
Old Aug 18, 2006 | 12:28 AM
kartattack's Avatar
Default Brake Light
OK, good luck!
Old Aug 21, 2006 | 07:50 PM
Lak's Avatar
Lak
Default Brake Light
Hey kartattack, well I got the quads to start okay, but there running lights don't work. The 50cc brake light blinks off and on when it gets bumpy. I pulled the bulbs out and both filaments look good. Does this have to do with the switch not having the running lights working? Let me know what ya think. Thanks Jim....
