Raptor questions
Old Dec 1, 2000 | 08:11 PM
TwinSparXR's Avatar
Does the Raptor use the same carb as the YZ400?
Does it use 2 cables or just 1 from the thumb throtle?
Any tps on the Raptor?
May seem like silly ?s but it's stuff I need to know, Thanks
Old Dec 1, 2000 | 09:42 PM
paulb's Avatar
no it is not a silly question , a lot of people want to know but dont ask.
it has two carbs but uses a single cable . the throttle is lighter than a blaster's throttle because you only need to turn two butterflies instead of lifting slides with stiff slide-springs.
dont know about the yz 400 .
Paul
Old Dec 2, 2000 | 03:32 AM
dstevens's Avatar
the raptor has 2 33 mikuni bsr carbs, the 400 uses a single mikuni fcr carb
Old Dec 2, 2000 | 02:42 PM
TwinSparXR's Avatar
Thanks
Old Dec 2, 2000 | 07:00 PM
86atc250r's Avatar
Keihin makes the FCR 39mm carb used on the YZF, not Mikuni. The FCR 39mm is also the carb of choice for many high performance carbureted street bikes.
The Raptor carbs are BSR CV carbs by Mikuni.
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
