brand new 686
Old Aug 16, 2006 | 10:22 PM
getblown's Avatar
Default brand new 686
Just did the 686 conversion to my raptor, managed to fire it up this afternoon and it made an awful knocking noise which I hope is coming from the top end. I adjusted the valves before I put it all back together and everything seemed to go very smoothly, other then the possibility of out of adjustment valves what else could it be??
Plus, I was reattaching the throttle cable to the carbs and something must have happened but the spring that closes the throttle plates popped off and now I can't get it wrapped back around again. Any ideas on either would be great, thanks
Terry
Old Aug 17, 2006 | 02:49 AM
Z40005BR's Avatar
yeah dont start it until you know the problem...you prolly have the valves adjusted to the wrong stroke and with the carbs, i dont know what ur talking about, are you talking about the spring thats on the needle?
Old Aug 17, 2006 | 10:39 PM
getblown's Avatar
I got the spring issue worked out, but am still having troubles with the loud ticking. I pulled it apart again and made sure the timing was right as well as re adjusted the valves once again but with the same result. Another thing I noticed was alot of air moving out of the cranck case vent as well as out of the oil resovoir, not sure if that is normal. Any help at this point would be much appreciated.
Thanks, Terry
Old Aug 18, 2006 | 08:58 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
I would be willing to bet your decompression pin is 180 out on your camshaft.
Old Aug 18, 2006 | 05:56 PM
getblown's Avatar
would that cause the knock??
Old Aug 18, 2006 | 10:43 PM
getblown's Avatar
hey, thanks, that was it, fixed it right up. No ticking and a whole lot more power. thanks again,
Terry
wendal
Sep 7, 2019 06:46 AM
EIF
Apr 20, 2017 07:15 PM
fredrikrosen
Oct 29, 2016 07:56 PM
fredrikrosen
Sep 28, 2015 09:58 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
