i still need help.....
Old Aug 17, 2006 | 02:32 PM
matts01ds650's Avatar
Default i still need help.....
so from a previous post i told you all how my ds would start, idle and ride at a moderate pace but once i hit the gas it would spit and sputter and eventually die....i replaced the voltage regulator, cleaned the carb 3 times now, i even got a new cdi.......but its still doing it.....so whats next????
Old Aug 17, 2006 | 03:01 PM
supersonictoys's Avatar
has the bike been doing alot of sitting? how long ago was it that it ran right?
Old Aug 17, 2006 | 03:17 PM
BioWare's Avatar
Toxic Ryder
Here's a shot in the dark but, try the timming, plus put new plugs in, and if the bike has been sittin for a long time drain the gas and put new in.
Old Aug 17, 2006 | 04:39 PM
its been at least a month or two.....i bought new plugs..just put them in and still the same...ill go get new gas now....how can i adjust the timing????
Old Aug 17, 2006 | 05:38 PM
bombrider04's Avatar
have you checked the ventline from the gas tank and what color were the other plugs that you just took out try putting the quad on reserve and run it for a little while and see if there is any difference...are you running any mods and if so what and jetting...get rid of all the gas from the tank and carb and go buy new gas and see if that makes a difference make sure the airfilter is clean
Old Aug 17, 2006 | 05:41 PM
if no one has ever taken your motor apart before I really doubt it would be your timing. just for kicks why not remover the carb bowl and check for water. I have had the very bottom of the bowl get about a teaspoon of water in it and it will idle fine but when you rev it, it gets enough vacuum through the main jet to draw the water up from the bottom and the motor dies out. this would also give you a chance to make sure your main jet isnt laying loose in the bottom of the float bowl and also make sure there isnt a foriegn object stuck in the main jet.
I know you said that you cleaned out the jets but did you check to make sure the pilot jet and all the other jets are able to be seen through and that when you hit the gas the butterfly and other stuff work properly...also that the <u>choke isn't on</u>
Old Aug 17, 2006 | 05:43 PM
sonic to me the problem seems as if its the gas and from sitting a long time and there has been junk or something in the gas and the jets are clogged or the fuel petcock is clogged or mayeb he got bad gas or water as you said
Old Aug 17, 2006 | 07:14 PM
so.....with the new gas i got nothing....the old plugs were black all messed up and the new plugs started to look like the old after one short ride....so i said $%@# it and took the carb off for the 4th time....checked out the diaphram very closely and found two tiny holes in it.....do you guys think this could be the problem.......no vaccum to open her up???? i know someone asked me this before and i apologize for not being more thorough.....
My ds has a pro-circuit 4 pipe, k@n, and a 185 main jet......all done by previous owner....
Old Aug 17, 2006 | 08:14 PM
jusrlax's Avatar
If you have a Mikuni main jet, a 185 is too rich, which may be causing your black spark plug. If it is a Dynojet main jet, you should be pretty close. At sea level, most people use a 170, 172.5 or a 175 main jet (assuming Mikuni, not Dynojet). This is also assuming you are running with the airbox lid on. You also want the "c-clip" on the needle to be in either the third, fourth or fifth slot, counting starting from the sharp end up.
