More LT80 Fun: Won't Start
Old Aug 18, 2006 | 05:12 PM
TEXWS6's Avatar
Default More LT80 Fun: Won't Start
Replaced the starter relay, and the battery is good. What do you guys suggest? I can hear the starter relay clicking.
thanks,
Kelly
Old Aug 19, 2006 | 01:34 AM
Radrob99's Avatar
is the engine frozen? pull the plug and try
if you can hear it click I would now check and make sure its getting the power.
if it's getting power then your going to have to pull the starter and make sure its free.
if its free then I would bench test it to see if it spins could be just brushes or the armature is bad if the bike got wet the starter is probably just stuck.
Old Aug 19, 2006 | 11:59 AM
TEXWS6's Avatar
you are good, the problem started just yesterday, the night before, i had my daughter wash it with a water hose....i don't understand how you guys get the starter out with nerf bars, etc in the way!!
Old Aug 19, 2006 | 02:27 PM
TEXWS6's Avatar
well i feel like a DOPE! i called the local dealership and they mentioned a reset button on the quad that i have never heard of before. Well, i pushed the reset button in and now it is cranking. BUT
It won't turn over....any suggestions?
thanks,
kelly
Old Aug 19, 2006 | 11:22 PM
Radrob99's Avatar
ahhh the old hose in the bike trick,
make sure you have spark, if you have spark, drain the float bowl,if still dont start, hit with starting fluid and see if it starts ( be carful no oil in starting fluid 2 strokes don't like it just a little) if it fires you have a fuel problem if it doesn't its usaully
a weak or no spark or compresion, probably just got some water in it though
Old Sep 5, 2006 | 11:55 AM
RABDAB's Avatar
Where is ths reset button ? Good thing to know.
Old Sep 5, 2006 | 07:20 PM
Hymis's Avatar
reset button is below the right rear fender. The carb might be full of oil from the auto injection. Turn the petcock wide open so the gas will free flow and choke it. That might flush everything out. Also remove the plug and try and start it, this will eject any junk in the cyclinder.
yagerzzz
Jun 24, 2015 07:45 AM
clsharky
Jun 8, 2015 11:38 AM
Dieseltrash
Jun 6, 2015 09:53 PM
1000gade
May 27, 2015 12:37 PM
Lasher
Jun 8, 2000 11:43 AM
