Caster and Camber on a Jetmoto 200 ?
Old Aug 23, 2006 | 07:21 PM
SherpaT350's Avatar
Default Caster and Camber on a Jetmoto 200 ?
Just wondering how you guys are setting up your front ends on the 200 ? How much caster and camber ?
Also, did you guys grease your pivot bolts on the a-arms where they mount to the frame ?
Thanks,
D.
Old Aug 23, 2006 | 08:55 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Thanks,
D.
I dont have adjustable a-arms on my 200. All i did was check that when the handlebars were pointed straight so were the wheels. I only made sure the bolts were tight.
Old Aug 23, 2006 | 10:57 PM
SherpaT350's Avatar
I have any adjustable bolt/nut combo at the top of the a-arms that look like an adjustment , does this mean I have a newer model than you ? I also an suppose to have the upgraded suspension . How can I tell ? I do have yellow springs around the front shocks , is this the upgraded shocks ?
Thanks,
D.
Old Aug 24, 2006 | 12:24 AM
Radrob99's Avatar
my buddy purchased 2 150's they have same frame as 200 what we did was just set them plum (straight up and down) one was ok the other one was 3/4 of an inch off you could see it. as for greasing these are not normal zerk fightings like a car. on my other bikes I changed the zerk then filled with grease, the jetmoto's we haven't greased yet, but will probably change the zerk too because grease gun doesn't fit on zerk fitting.
Old Aug 24, 2006 | 12:29 AM
Radrob99's Avatar
oh and as for the suspension one bike has an air fitting toward the bottom on the side of the shock the other bike does not, kinda wierd, same shock just different fitting the funny part is these bikes are only 30 bikes apart according to the vin #, we haven't checked to see if the air fitting does anything or not yet.
Old Aug 24, 2006 | 10:07 AM
KTM Patrol
Former Chinese POW!
Thanks,
D.
Yes you do have an newer model than I have. Im not sure about the suspension difference, my springs are yellow also. They might have changed the spring rate and you might have one of the newest 200's too. Im not sure but I will be seeing Eugent this morning and will ask him what is current on each model.
Im also not sure about the 2 different fittings on the front shocks. Im also confused about the zerk fittings, mine all accept a common grease gun.
Old Aug 25, 2006 | 08:46 AM
KTM Patrol
Former Chinese POW!
The 200 is the newer longer wheel base model. It also has the rear shock located in a new place and the shock itself is new also. The front suspension is the same except for the adjustable a arms. I would think the longer wheel base would help this quad's handling out and its also a inch or so taller too.
Old Aug 27, 2006 | 08:53 PM
Radrob99's Avatar
wmq, Its not that the grease gun that doesn't fit it's just that the zerk doesn't have the llittle ball on top to hold the tip on when you pump the gun, also doesn't have a little one way ball in it to keep dirt from going in. not to get off subject have you adjusted your valve's on your 200 enduro, I have simalar bike and had to just about pull engine to get valve cover off, ended up grinding one off the fins down on the side to get clearance to put back on.
Old Aug 28, 2006 | 11:41 AM
KTM Patrol
Former Chinese POW!
Oh OK. I havnt had that problem but did have a couple of zerks broken off on the bottom. I figured it was probubly from removing the quad from the crate.
Its kinda funny about the 200 valve cover. I just tried to take that off this weekend, to take a look inside and couldnt get it off. There is not enough room with out pulling the engine out first.
Old Aug 28, 2006 | 07:48 PM
SherpaT350's Avatar
MyWife,
Well, that is very discouraging . Why would someone build an atv that can't be maintained without pulling the engine ? That really depresses me.
D.
