Caster and Camber on a Jetmoto 200 ?
Originally posted by: SherpaT350
MyWife,
Well, that is very discouraging . Why would someone build an atv that can't be maintained without pulling the engine ? That really depresses me.
D.
MyWife,
D.
yeah, I had to lower the front of engine and slide it out the right side then I pushed it up and ground off the left fin tell the valve cover didn't catch the frame. it was a pain in butt , but now I can remove it easy, also check your seal in your rear wheel mine was to big.
do the 200's turn as bad as the 150 (big radius) we ground down the stops on the 150's made it alot better, also anyone notice, we have one tire that is larger than the other's they all have same measurements on them just one looks bigger I'm going to have to check the air presure and make sure its the same,
