99 scrambler problem again
Old Aug 24, 2006 | 12:45 AM
79Oakley's Avatar
Default 99 scrambler problem again
well this is getting old. took my bodies scrambler out for a ride. he leaves it at my house. it felt wierd in the rear like it was floating. when i got it home i soon discovered that the bearing in the axle are gone bad. i have it tore down to the little hubs that your sprocket bolts to on one side and the hub that your rotor bolts to on the other. i can not get them off. i see that they are threded but i can not get them broke loose. are they reverse threads. any ideas will be helpful. i am going to try heating them tomorrow i think. it see every time i ride it i find something wrong with it. oooooo well it is a 99 with a hard life under it. how much is it to replace all the bearings.
Old Aug 24, 2006 | 08:07 AM
ftwflh's Avatar
If you are talking about the axle jam nut it is faster and easier to get a new nut and use a dremmil tool with a cutoff wheel to cut the nut in a couple places and then split it with a chissle.
Be careful no to mess the threads up!
The cheapest place I have found for bearings is PiviotWorks www.pivotworks.com
Old Aug 24, 2006 | 11:45 AM
bjrjr16's Avatar
ftwflh is right, On my uncles wheeler we had to heat them up and that got them off. But on his other wheeler they wouldnt go so we took the hand grinder to it. Brian
Old Aug 25, 2006 | 12:36 AM
79Oakley's Avatar
i got the axle out had to use a pipe wrench and 4 ft piece of pipe. i still have to get other nut off the other side. everything was gone. one side the bearing was not even their just some metal. is there a place were i can buy a hole rebuild kit with all the bearings and seals.
Old Aug 25, 2006 | 08:53 PM
lslubecki's Avatar
Radmfg.com sells billett aluminum rear bearing carriers for polaris scramblers with double roller brgs and tapered roller bearings. They cost about $219.00. Lubed externally and look really nice. Comes comple and assembled.
Steve
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
